wetdec
There seems to be some confusion on weight of tiles that can be used on plaster board with a number of figures being banded around from varying sources.
These are extracts from British Gypsum plaster board manufacturers tiling document issued April 2006 and is their current standing on the subject.
Tiles can be applied to drylined walls or the surface of lightweight partition systems to dado level or above. Tiling can be carried out in any type of building eitherb in dry areas or in areas subject to intermittent moisture conditions. Tiles up to 12.5mm thick with a maximum weight of 32kg/m2 can be accomodated (20kg/m2 for a plastered surface). The tiles are fixed using a suitable thin-bed adhesive to a nominal 3mm thickness.
Timber stud external walls or partitions ; where tiling is specified, designers should ensure that the timber is of sufficient dimensions to give a stable base for the additional loading
Tiling directly onto plaster : Before tiling commences any tapered joints should be filled with tile adhesive.
Tiling onto plaster : tiles up to 20kg/m2 can be applied directly to the thistle finish coats, except where the system includes a bonding agent. In this situation the total weight of tiles and plaster applied over a bonding agent is limited to 20kg/m2, therefore consideration should be given to tiling directly to the background. If plastering to provide a backround for tiles avoid polishing the surface. Polished plaster should be roughened and a suitable primer used. Tiles should not be applied directly to thistle undercoats with the exception of Thistle Dri-Coat
