White Room
Plaster is 20kg m2 and plasterboard is 32kg m2...
Why would u use a rapid adhesive on the wall mate?
There's no need. And it'll make hard work of it.
I did not win the lottery ?. Marc and just lucky. because in italy heavy air. tiles read more 🙁
capito una BEATA M.Nchia .....Just lucky! Hahaha
It was a carefully constructed educated stab in the dark
I'll have you know! Haha
simon 70 compry?capito una BEATA M.Nchia .....
Could you cut the old board out and put tile backer board in instead? Sometimes it is worth the extra hassle for piece of mind. As you say you are 3kg over, which to be blunt is still over. Hardiebacker or aquapanel would suffice.
The best way to sort out paramount board is to take the single sheet of plasterboard down, hack the cardboard squares off with the back edge of a handsaw- this sounds demented but it really works.
Then use building adhesive (gripfill, pink grip etc, solvent based) to bond CLS timber on its side to the plasterboard you are left with. Then the following day screw your board onto the CLS.
This also give you the opportunity to get the wall flat by bonding the CLS on perfectly Plumb and flat.
Prep work like this is fairly time consuming but it means you are starting the job on the perfect wall. Starting a job on a compromise often means the finished product is also a compromise.
