Discuss Tiles are 250 x 750 - Trowel size!!! in the Canada Tile Advice area at TilersForums.com.
charlie1
Does back skimming really help adhesion of the tiles?? Wall or floor, only ever done this with travertine.
perfect trowling technique: spread substrate with flat side of trowel then serrate, this compresses the adhesive and improves adhesion quite considerably rather than just applying with combed side of trowel ( its also cleaner Imo), then back skim tile. Now,... Assuming all that has taken you under 2 mins to do then you have the perfect adhesion when you twist tile in to place, only spread for 1 tile at a time with those! Tiles that size and above usually take me 10 minutes to set each tile so take your time. A rubber sucker will aid your leverage when moving tile in to its final position.
Reply to Tiles are 250 x 750 - Trowel size!!! in the Canada Tile Advice area at TilersForums.com
Hi guys, had some great advice here before so thought I would ask here for advice again...
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
Hello, Due to slight small bumpy-ness in wall I hope to be able to level it out when setting 12...
Hello. Doing... ( extremely slowly ).. a walk-in shower & additional soaking tub area 1) What...
We had a wet room fitted by a large company. We have issues with a few large steps where the...
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
