Discuss Tiles cracked again in the Canada Tile Advice area at TilersForums.com.
So earlier last year I had my whole bathroom done up including new was and floor tiles.
A few months into it however I noticed the tiles on the bathroom flors has started to crack
The cracks grew longer luckily the tiles was doing another job and he had a looked and was very confused (and upset)
He kindly agreed to do remove the tiles and relay a new set. These were done however they have started to crack again!
He used flexi glue and the first time around he used tile backed boards the second time around he used plywood.
My question is is this the tiles? They were t cheap or is there something wrong with my floor? I had rentokill come out the first time to check the joints and they said they were fine.
The tiler has done other work for me which has been fine so I’m at a loss.
Have they cracked in the same place both times
seems like it
[automerge]1586272902[/automerge]
could be to much movement in the floor and cheap ceramic tiles..
the tiles were very expensive and the odd thing is it’s only the middle tiles that this seems to have happened
Ajax123
1,213
Lincolnshire
cheap or expensive tiles will crack if there is too much flex i the subfloor. I suspect that is your issue. get a glass of water and place it on the floor. Then walk on the floor, and then jump gently on the floor to see if there is "bounce" (the water will ripple) if there is bounce that is your issue. a bouncy floor is not suitable for tiling.
Reply to Tiles cracked again in the Canada Tile Advice area at TilersForums.com
Our house was renovated 5 years ago, builders were pretty shoddy. One of our shower rooms is...
Had new bathroom by a builder who has subsequently gone bust and after 6 months the floor has...
We had a wet room fitted by a large company. We have issues with a few large steps where the...
First time tiling, lots of mistakes, but most of them have been resolved in a timely fashion so...
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
United kingdom
What member type are you?
  1. Homeowner
Tiles cracked again
    Votes: 9 5.5%
    Votes: 15 9.1%
    Votes: 12 7.3%
    Votes: 49 29.7%
    Votes: 20 12.1%
    Votes: 38 23.0%
    Votes: 4 2.4%
    Votes: 2 1.2%
    Votes: 21 12.7%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 3 1.8%
    Votes: 5 3.0%
