Q
Qwerty
Yep, sounds like tubbed addy is the issue
I'm not so sure!?! The lead flashing may have failed on the chimney stack, and water is running down the wall. Or it could be condensation, as he's said...
If its a wet area, then I'd agree, as he shouldn't have used tubbed gear in a wet area anyway.
I am sure the property owner would notice if the lead flashing has failed and water was running down the wall - but we are asked to give advice with only bits of information and a lot of guessing so it's possible that there isn't even a roof on the building!
At the end of the day the chimney may be a red herring and it's water ingres through the joints where the grout has cracked, he may have tiled onto emulsion and this is the result of the drying out or ............
Hi all
The tiler that did the work (before I got involved) insists that the problem has been caused by condensation but I don't buy that as surely the wall should withstand water etc from a shower.
The Op stated a shower area.
Would suggest tiler is making an educated excuse!
