Discuss Tiles laid on Pads in the British & UK Tiling Forum area at TilersForums.com.
rossi
Looking for advice on this one please.
I am a self builder. I have had a guy, whio says he is a tiler, lay 100 sq m of 600mm sq porcelain floor tiles over a concrete floor which has water based under floor heating in it. Due to the concrete floor not being perfectly level, he said that the tiles had to be laid had to be laid on pads. These only cover about 50% of the tile area underneath the tile. In addition he has used rapid set adhesive. There are huge voids underneath each tile. The have been filled using a flexibile grout.
Result: About 40% of the tiles are now loose. The grout is all flaking and dropping out. No doubt due to the tiles being put on pads and not having anything under the grout to keep it in.
Has this been laid correctly? Can tiles be laid on pads. Has the correct adhesive been used?
Do I have any comeback with the Tiler?
Advice please.
L
LM Ceramics
Rossi im afraid your tiler is another john wayne (cowboy) floor tiling should be a solid bed fix meaning 100% coverage or near enough if a floor is uneven then the tiler should have told you to level it, in some cases if the floor is slightly uneven you should still spread the adhesive onto the floor. Rapid set adhesive is a big no no for porcelain he should be using a flexible adhesive. as soon as these muppets get out of our trade the better.
i cant see your tiles sticking for long i can see it being re tiled soon
Droopy
I thought he used flexi adhesive.
But reading it again, it was not. Just flexi grout.
So, sorry Rossi, there was no good news.
GazTech
Advice please.
Rapid set is not suitable for UFH.....
Reply to Tiles laid on Pads in the British & UK Tiling Forum area at TilersForums.com
Tiles laid on Pads
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
