Hi all,
I’m hoping someone can help.
in June 18 we had some tiles fitted to the kitchen and hall, along with electric underfloor heating.
the tiler used insulation pads, then applied the electric matting, and the tiles were stuck to that surface.
We were instructed not to turn in the heating for some weeks , and then gradually increase it by one degree a day. As it was June we didn’t need the heating for some time. It must’ve been about 3 months later before we used them.
About 6 months ago a couple of the tiles started making a hollow noise when walked upon. This has quickly spread. Most of the tiles are now effected, the grout is cracked in a lot of places, and you can even see movement with some of the tiles.
The tiler did return to look initially, but on setting the extent of the problem he’s blamed the heating and is now refusing to answer calls.
I’m keen to see if we can fix this ASAP, before tiles start cracking. I’ve bought some fix-a-floor adhesive after searching For people with similar problems but I’ve not been able to apply it myself as the grout is only 2mm thick.
Can anyone please offer
A) any advice on how to cut holes in 2mm grout without damaging the tiles, and then squirting in the adhesive?
B) offer any other advice on how to fix the problem?
C) be willing to help resolve the issue? ( I’m based in north Manchester)
Any help at all is appreciated
thanks
thanks
