H
hungover
hi all
I am currently working with 615 square porcelain tiles (11.5mm thick).
My cutter is a Rubi ND180 with a Marcrist CK850 blade.
I am having a mare cutting straight lines. One cut, earlier, was 5 mm out over its length. I could see it deviating but couldn't correct it. I can only put it down to the tiles being to heavy to slide across the "table" correctly. Any suggestions as how to reduce the friction? I have noticed that they are starting to score the plate.
