Purak
Hi all,
I have undertaken the task of tiling my mother's bathroom. Having removed some old wood/cardboard panel boards from around the bath, I found old damaged tiles underneath, which must have been done by the previous owners. I have now removed all tiles as well, and some of the plaster came off with the tiles as the plaster was obviously old, and quite moist in some parts.
Having had limited time and no real expert advice, I have chipped away all the damaged plaster, applied some plaster repair solution and left for 48 hours.
I am now about to start fixing the tiles, but would like some advice to make sure I am not making total mistake with this. We are using (not my decision, I'm just carrying out the job) 30 cm x 60 cm (8mm) matt porcelain tiles with 30 cm x 40 cm (9mm) glossy ceramic tiles. I have bought a bag of 20 kg CFTA Flexible GranFix adhesive. I'm just wondering if this is good adhesive to use for the job or should I change before I start the job in the morning.
Also, even though on the bag it says this is suitable to even use for swimming pools, I would like to know if I need to add anything to the adhesive mixture before using it as this will be for a bathroom.
Any tips, feedback, advice would be highly appreciated.
Many thanks
Purak
Many thanks
Purak
