Discuss Tiling a ceiling?!?! in the Canada Tile Advice area at TilersForums.com.
Sanctuary
Hi everyone,
I've been tiling for several years now but today I have experienced a first..."could you tile my ceiling?"! Has anyone else done this? Or even been asked to do this? I thought they were taking the mick at first but they were serious, I said I would research it and what better place to start than with asking you guys/girls :)
Thanks for any help
stephenoneill
make sure ceiling is solid and can support weight ; using the flat side of the trowel spread athin coat on the ceiling ;skim coat basically then apply adhesive to the back of tile as normal ;the trick is to run a bead of adhesive all along the edge of the tile this will cause an air suction holding the tile in place hopefully ;best of luck
ScannedImage012.jpg ceiling.jpg slate ceiling.jpg Picture 2130.jpg Yes, ceilings can be tiled, been there, done that. Good Luck! Home - TileMarbleGranite
Reply to Tiling a ceiling?!?! in the Canada Tile Advice area at TilersForums.com
Hello, first post, asking about career change and possible entry route into the industry. I know...
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
