Discuss Tiling a floating floor, How would you go about it in the British & UK Tiling Forum area at TilersForums.com.
peckers
Hi guys and girls, I have been to look at two bathroom floors today that have been previously tiled.
The floors are floating floors and they consist of tiles laid with single part flexible adhesive onto 18mm chipboard onto polystyrene panels at 75mm thick which is then onto dpm laid on concrete.
And yes you guessed it, it has all cracked!!!
Now the customer wants it re tiling!
Now this is how I am going to go about it, if you have any better ideas on how to do this then please chuck your comments or critisisums in please!!
  1. Remove bathroom suites totally
  2. lift tiles and chipboard flooring and polystyrene
  3. I am going to cut the chipboard leaving 1" of the original protruding from under the skirting,skirting is to stay as is.
  4. fix down 3x2 timbers on top of the dpm to concrete floor at 300mm centres and put in noggings making sure this is all level and solid.
  5. I am going to double up on the 3x2 around edge of skirting board allowing it to go under the 1" of original chipboard that is staying.
  6. Reinstate the polystyrene insulation.
  7. Prime the back and edges,Then fix down 18mm wbp ply(marine grade) to the 3x2
  8. Give the face of the ply a coat of pva(not really:lol:) ACRYLIC PRIMER.
  9. Then tile the floor with 300x300mm tiles useing bal fast flex adhesive and flexible grout
  10. Then seal the grout and Silicon against skirying board
  11. Reinstate bathroom suite.
Right then i think thats it so fire away any comments, suggestions, critisisums welcome :smilewinkgrin:
Reply to Tiling a floating floor, How would you go about it in the British & UK Tiling Forum area at TilersForums.com
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
