Guest viewing is limited
Discuss tiling a new conservatory in the UK Tiling Forum area at TilersForums.com.
tactile
i was due to tile a conservatory floor in a weeks time. natural slate on to a concrete floor. the builders have just finished the conservatory today (although the actual floor was finished a week ago). do i have to wait 3-4 weeks before i can do this job or can it be done next week???
does the floor have to dry out like newly plastered walls?
GazTech
If you need a fastrack installation....you can use this onto concrete that hasn't cured properly....Gaz
BAL Green Screed Adhesive
A grey, highly flexible, water and frost-resistant tile adhesive suitable for fixing all types of ceramic floor tiles, including porcelain, ceramic mosaics, terrazzo, natural stone (excluding marble) in interior and exterior locations. It also provides enhanced adhesion to low porosity substrates. Suitable for situations where fast track installation is required, i.e. recently laid screeds or concrete. Suitable for use in showers and swimming pools.
Coverage: Depends on the nature and flatness of surface:
Thick bed solid bed trowel = approx. 3.5 – 4kg/m2 Bed Thickness : 3-6mm (up to 12mm in localised areas) Open Time: 20 mins Setting Time: 24 hours Packaging: Available in 15kg bags Shelf Life: 12 months when stored in normal, dry conditions. Protect from damp. Temperature Resistance: -30°C to 70°C Pot Life: 5 Hours
The Bal 10 Year Guarantee
Click here to download
Material Safety Data Sheet
Product Data Sheet
DHTiling
You can also use ditra mat..as it is a vapour equilisation mat as well and ideal for this type of project........It also can be got from CTD.....
Equalisation of vapour pressure
The interconnected air channels between the cavities on the underside of the Schlüter-DITRA matting remain open. This allows moisture in the substrate to evaporate, thus neutralising vapour pressure.
Reply to tiling a new conservatory in the UK Tiling Forum area at TilersForums.com
Wall & Floor Tiler Queensland Australia Tile Right About the role Seeking a Wall & Floor Tiler...
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
