Discuss Tiling a window reveal in the British & UK Tiling Forum area at TilersForums.com.
ag1975
How do I tile a window reveal? I think I should fix the reveal tiles first, with the trim...is it best to press the trim down on top of the adhesive for it to stay in place?
With the vertical tiles below the reveal, should I be using a batten, then tile up to them afterwards?
Where do I fix the trim exactly? I can't work out where the trim should start and finish to the exact mm, having a bit of a mental block haha.
Has anyone got any more tips?
:helpsmilie:
Muse2k8
Tile the "vertical" first using the highest point of the window as your mark. Cut ALL tiles to this so if the reveal is not level you will have a lip. This is good.
Then stick down your trim which will now be level.
Using a wee boat level to help you then want to pack out your reveal tiles to be level.
By doing this everything ends up level and straight plus it's so much easier than doing the reveal first and trying to get the wall to work.
Oh and please match up the grout lines...
Muse2k8
Btw is this a DIY project? Have you set out your tiling etc? I ask because well... Of most of your post really. Your batten will already be in place and you will fix to your first full tile off the window ready to add your cuts up to the edge. Cut your trim to the length of the edge and mitre it. File down as necessary till they fit square.
Reply to Tiling a window reveal in the British & UK Tiling Forum area at TilersForums.com
Hello everyone. My building had bricking work done on the outside and it seems in the process...
We recently finished a bathroom renovation where the two builders who did the bathroom also did...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
