Discuss Tiling a worksurface in the British & UK Tiling Forum area at TilersForums.com.
Shultzy
Hi all, apologies if this is in the wrong forum.
I am building a new kitchen and swimbo has convinced me that a tiled worksurface would be good. 35 years ago I embedded large floor tiles either side of the cooker and have not seen any adverse effects. Recently we saw floor tiles in one of the sheds which had a specific warning on the box "Not to be used for food preparation".
My questions are :-
what type of tile is safe for use in kitchens (600mmx600mm floor tiles not black granite)?
do I need a special adhesive?
do I use a two part epoxy grout?
is MDF ok for the base?
any other issues?
K
kendo1
Probably. I've never done this, others may have had some experience.
I'd reckon that if you can walk on it, it would be okay.
A couple of things to consider:
someone will use a knife on the surface, will it scratch?
will the surface be resistant to heat from very hot pans?
what happens if you drop something hard on it, or maybe putting a mug down a wee bit too hard?
how will you finish off the edge?
Reply to Tiling a worksurface in the British & UK Tiling Forum area at TilersForums.com
gamer1
Hi guys, i took some jobs as a contractor for some MC Donald's restaurants but i find it quite...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
