Tiling bathroom floor - DIY
Hi all. Having a few problems tiling for my first time.
Main things..... I am using Flexible tepid set tile adhesive called Pro Rapid Rs. When I mix to manufacturers specifications I find it too thin and just collapses into the groves made by the trowel when laying it. Any one else experienced this?
Furthermore, I boarded the floor with ply (later found out about this mesh stuff so ply already fixed) I then primed the floor with a sealer/primer from screw fix. I've since seen conflicting information on whether you should prime the tiling surface of ply or not. Will it be OK primed or should I sand it off?? Why do some sites say not to prime the tiling side?
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 2 1.2%
    Votes: 5 2.9%
