David Dudley
Hi.
I recently removed all my old floorboards and replaced with 18mm Marine Ply.
This I thought was the best thing to do as advised in other posts on other forums and on here.
I have now seen contradictory advice.
The room is 1.6mx3m and most of the floorspace will be taken up by sink,basin and bath. It's a jack 'n Jill style room with a 1.6m length walkway between two opposite doors.
I have drilled the boards at 150mm centres directly to joists and put nuggins in accross the joins.
The thing that I didn't do was seal the edges and underneath. The bathroom is above a living room.
I plan to tank the walls of the shower/bath area.
There is no option of replacing the marine ply as it's now in place and would need cutting up to get out.
I was thinking of tanking the floor too. (Not a wetroom but to make it splashproof as I don't want water damage into living room below)
Would Ditra matting be recommended for this?
I have seen the un-coupling membrane? Is this designed specifically for this application? I've read about warping and obviously the cracking issues so any advice from where to go.
Any recomendations?
Thanks.
Any recomendations?
Thanks.
