Discuss Tiling floors.. 12mm ply help!!! in the British & UK Tiling Forum area at TilersForums.com.
L
leeroy
Hi peeps
First post and its a question!! I want to tile my upstairs bathroom and i am un sure what to use on the floor as a base, At the moment i have t&g floorboards but have been told to use 12mm+ waterproof ply layed over the top??? is this right? i just thinking its going to be rasied quite high once tilied?
Thanks in advance!
Lee
UKTT Darren
TF Official Sponsor
Subscribed
195
828
North East
This is correct, screw it down every 300mm and squirt some no more nails down as well, use 25mm lenght screws called turbo gold from screwfix so it doesnt go through and hit any pipework. The heigh can be offset by a door trim from any tileshop or diy shop
devonmark
Hi Leeroy, welcome to the forums, if the height is an issue, you can always use hardi backer board or no more ply backer board, they come in 6mm thicknesses, the hardi is readily available at the likes of topps and no more ply is available at tile giant. It comes in 600 x 1200mm sheets. To fix use a polyurethane glue on the back and screw every 250-300mm, use plasterboard screws and countersink them..hope this is of use...Mark.
Daz
Hi Leeroy and welcome to the forums.
All the previous posts are correct. However, if the floor boards are deffo tongue & groove and they are securley fixed you can tile directly onto them.
Please see an exert from Ardex brochure, below....
Existing tongue and groove floor boards of
traditional construction should be screwed or
ring nailed down to the joists to provide a rigidly
fixed, flat and adequately braced surface.
Any existing floor polish, wax, old adhesive etc.,
should be removed, e.g. by sanding to expose
a clean surface prior to tiling.
The full brochure is, hopefully, attached.
View attachment ARDEX-FLEX%207001.pdf
Reply to Tiling floors.. 12mm ply help!!! in the British & UK Tiling Forum area at TilersForums.com
A little help guys. I've been asked to price 71sqm of limestone flooring. My issue is this...
    Votes: 9 5.3%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.7%
    Votes: 21 12.3%
    Votes: 40 23.4%
    Votes: 4 2.3%
    Votes: 4 2.3%
    Votes: 24 14.0%
    Votes: 19 11.1%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
