Discuss Tiling flush to doorway, no facing/architrave in the UK Tiling Forum area at TilersForums.com.
Julz77
Evening all
looking for advice on tiling to a doorway with no architrave, like a 'wet room style'
tiles are 250 x 400 x 8 white ceramics. i have added a couple of pics of the area, but am a bit concerened about a couple of things
- the wall on one side of the door is only 55mm wide..so obviously a crappy cut to make, should i leave it and advice to get architrave back in?
- if it is possible to tile up to the door, what gap should i leave between last tile and door way? I have 10mm genisis trim. concerned about when door goes back in the the tile being damaged
- (this might sound mad but.....) is there anything like a thick door trim that i could use on the small wall and still get the wet look room on the other side and the top? or would that look crap?
sorry the pics are wrong way round, not sure how to shift them round!
really appreciate any help and advice!
Julz
Julz77
No its new plaster coat on crappy old squinty nightmare walls,,,,,old tiles taken off last week, terrible state some put up with silicon not addy and some packed out with broken tiles behind...
Its had 2 coats of plaster but still out in places by 10 mm. not best pleased with the plasterer as he also put a bit of wood (looks like an old floorboard!) on the window sill, when i asked for plasterboard as tiling into the revel.
Your right about the door tho, just advice them to get architrave put back in, cant think of any way of making it look ok.
have another door way in the room but doesnt have a door on it (walk in alcove type thing) so least that should be easier! .....i hope
kilty55
1,113
edinburgh
yeah ok just be careful julz make sure its totally dry before applying anything julz is my advice ...might take a bit longer to be ok imo
gives you time to get shot of the floorboard the guys rammed in the window for you lol
i saw a plumber try to patch a shower wall with the laminate floor he lifted form the rip out honest and he expected me to mosaic over the top of it !!
Julz77
hahha true ! floorboard tho eh? what do they expect us to be able to achieve with a tile and a bit of addy on that kind of crap?
I have a horrible feeling its still going to be patchy ....and this job will go on FOREVER...never mind gives me time to figure out how to make wall tiles flush when the wall resembles the cairngorms :-/
Reply to Tiling flush to doorway, no facing/architrave in the UK Tiling Forum area at TilersForums.com
I’m tiling a ground floor of a house approx 120m through a ground floor with 5 doorways in the...
I just set new porcelain 8 x 8 tile in my rear entryway (3 ft x 3 ft area). I love the results...
Hi, I'm tiling the floor of a wetroom and would like some advice on the best way to lay the...
I have a small kitchen with a floor area of 265cm x 140cm with the door recess adding another 20...
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
