Discuss Tiling flush to doorway, no facing/architrave in the British & UK Tiling Forum area at TilersForums.com.
Julz77
If you have a plastics supplier nearby you can get uPVC architieve, if you were after a maintenand free wetroom, no painting ;)
Not liking the sound of the walls though. Bonded and two skim coats and it's dipping out by 10mm??
Some of its 15 mm!! its a nightmare.
uPVC would be soooooo much easier than this fannying about!
macten
1,158
Nottingham
I was going to post the same Allister.
I used them in my own bathroom after my architrave (MDF mind) started to bubble in a couple of places.
Now use it all the time in wet rooms or bathrooms with poor ventilation.
kilty55
1,113
edinburgh
hi julz,the 55mm cut will be fine lots of doorways are this tight to the wall that i have done its just the finished trim that wont look right imo on this one
check the straightness of the wall vertically at door edges and if large voids are there show the customer these will be highlighted by trim work when you flush the tiling off
Julz77
It's easy to cut and shape with a grinder too.
Are you going to be able to fix if the walls are that bad? What addy are you using? Most constraints are 20ish mm, Your going to be breakign limist once back buttered and packed out 15mm.
Its weber set plus, just checked at says its ok for up to 20mm in small areas. as its 15 mm dips here and there hoping it should be grand. not rapid set either so should have a bit of time to play around.
just annoyed as i offered to plaster the walls myself, would have saved time as i would have gotten them sorted. customer aint best pleased that she paid to have them sorted and there not.
just the tile trim round the door thats confusing me. suppose if its what she really wants ill just have to go for it
Julz77
customer is in cyprus on hols, (least im 'home alone' to get on with it!)
plumber has also told her to use the tile trims so she fairly certain thats what she wants!
Martino
LOL!!!!.......IMO it would look better with the tile but just make sure u tell her about movement....unless the doors frame has been concreted in it will move!....the grout will prob's crack and fall out around the frame area too!....but what can you do.....explain this and then its upto them! :)
widler
1,328
England
don't see why it would be a problem at all using a trim instead of arc,ive done it loads,looks much better than arc.
Leave the trim back near the inside edge,leaving a gap bigger than a joiner would with arc,or the same.
If a tile falls off because someone slams the door its not because the tile laps the timber by 2 or 3mm its just bad fixing :thumbsup:
oh,and the plasterer is a bit rough,a good plasterer should always clean his woodwork and his electric boxers out:yes:
Julz77
Thanks for that Wilder
defo a rough plasterer had a wee look at the nick of the window revel...will post pics in a minute
Julz77
its not even level :mad2: ....... the bit off wood is already cracked and (although highly unlikely in Scotland for at least 9 months..and even then only be for one day...) when the sun shines it hits the ledge directly...so a bit concerned about it expanding and cracking more....
widler
1,328
England
no worrys,it shouldnt be a problem if done right.
how a few mm of wood would make a difference is beyond me,your tile would possibly not even be on the wood by 2mm,your trim another mm,then another 4 or 5 to the edge.
besides,once you have chipped the plaster off the casing,you will have a good few mill clearance underneath the tile ;)
widler
1,328
England
View attachment 46563 View attachment 46564
looks like you have plenty of room to plasterboard it mate,just screw some on
Reply to Tiling flush to doorway, no facing/architrave in the British & UK Tiling Forum area at TilersForums.com
I’m tiling a ground floor of a house approx 120m through a ground floor with 5 doorways in the...
I just set new porcelain 8 x 8 tile in my rear entryway (3 ft x 3 ft area). I love the results...
Hi, I'm tiling the floor of a wetroom and would like some advice on the best way to lay the...
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
