Discuss Tiling green plaster board in the Canada Tile Advice area at TilersForums.com.
Albert
1,253
Gateshead NE8, UK
I'm guessing green chipboard or MDF? Even if secured by using a ready mixed adhesive it will not last long. If not fixed then more likely too much flex for the tiles to adhere to. Do you know what type of board it is? Cheers
The title says plasterboard
eddcottee
493
Ipswich
Wedi sell ready made bath panels which you can tile onto. You may be best looking for one of those if looking to replace what you were trying to do originally.
Also, I assume when you mention a ready mixed adhesive, you are referring to what you stuck the tiles on the "green board" with? If so, that's no good and a powder adhesive will be what you need.
Also I would fit the panel first and then tile it, unless others on here suggest different?
Cheers
Edd
If its been primed , then the dispersion adhesive doesnt have any surface capillaries to adhere too or porous background to disperse.. what is the tile type ?
Cheers
Edd
Hi add thanks next time i think i will buy a ready made bath panel for tiling this time we replaced it with marine ply, but now although the tiles have stuck the grout has cracked. Is this because the tiles have moved?
Reply to Tiling green plaster board in the Canada Tile Advice area at TilersForums.com
    • Friendly
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
I'm having a nightmare trying to establish product info from distributors. For example...
Great Dunmow
What member type are you?
  1. Homeowner
Business Name
none
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
