Discuss Tiling into Recesses - die grinder? in the British & UK Tiling Forum area at TilersForums.com.
jrm1
Just spent a small fortune on marble tiles and intend to tile into recesses but have been wracking my brains about how to do this, seeing as you can't get round-overs made of stone. And we must agree, plastic would look naff.
Can anyone recommend the best tool for the job of polishing the exposed ends of the tiles (as you tile into a recess for example)?
Would an air die grinder be best? If so, which one - there are quite a few on the market. Getting into tight spaces would be a consideration.
silver
Hi, did a recent trav splashback, I dont like trims either on trav.
The wet cutter was sufficient, resealed the edges after cutting and applying.
The sill I leave an extra 2mm to create a sill but not too weak it will snap off and cut the sill into the side (slot it)...I like the finished results and have done quite afew like this now...if I knew how I would put pics on !!! LOL
Reply to Tiling into Recesses - die grinder? in the British & UK Tiling Forum area at TilersForums.com
Hi all, Have a question about how/when best to install tile trim - probably quite basic! One...
Q
    • Winner
    • Informative
So I was recently asked to fit some 3m x 1.5m 6mm thin porcelain in a new tile showroom. Mapei &...
8K
Qwerty
Q
I'm a chippy, I fit a lot of kitchens and some bathrooms, inevitably I have done quite a bit of...
20K
Hello, Never attempted a mosaic before, so thought I'd seek some advice. Only having used mosaic...
11K
seneca
11K
Rizzle from the Portizzle
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
