div
can you tell me the correct way to install it? I have a T+G wood floor. Thanks
it is stronger than 12mm wbp ply
for fitting
secure exsisting floor to joists,mark up ur walls were joists are.
lay out and cut b/boards to suit have them staggered"brickbond".
prime floor with bal apd or sbr (both ways) up and down room.
spf rapidset with 6mm trowel lay boards then were marks on wall for joist are screw b/b down with 12mm b/board screws leave 2mm gap between b/boards then screw every 150-200mm.
fiba tape over joins with spf rapid then tile away...
