Mmmm, is hanging a Swedish thing ? my Brothers ex partner spent a lot of time there tiling.
It's unusal for Swedish tilers to use spacers. The absolute majority of the time, tiles are "hung". When the tiles are too heavy, battens and rope are generally used.
i ping lines and
tile to them, from time to time i check joints are still evenly spaced and true
never used the rope method , is it a quicker way of keeping a consistant grout line and how does it deal with the variation in
tile size
It's easier to compensate for differing
tile-sizes using rope than it is using spacers, because the rope can be compressed without affecting other tiles noticably. Rope is especially useful when tiling very large vertical surfaces. Batten, fix the first row, place a length of rope on top of that row, and then slap up every other
tile, and then go back and fill in the gaps. The best example of this I can think of, is when I tiled a series of large walls in a bathhouse in 2007. The total meterage was over 100sqm, and the biggest section was about 9 metres high. Used several thousand tiles, which measured 125x125*20mm, with 10mm grout lines. Each
tile weighed something like 1,5kg, and slipped continuosly in the adhesive I had been supplied with, when unsupported. I battened the entire length, and on the biggest segment, which was about 5m wide and about 9 metres high at the highest point, I was able to fix about one row every four or so minutes. One row was about two boxes, and each box held 20 tiles.
It's still important to choose a good adhesive with good slump resistance and a setting time suited to your working pace.
This was the main problem for me on that job, because I could only do about 10 rows before having to leave everything to set for an hour or so, because if I did more the weight of the tiles started to compress the rope furthest down a mm or two. I had complained to the customer that the adhesive had too long open time and too little slump resistance before I started, but they wouldn't listen. They ended up paying for it though, as it took more than twice as long to fix the tiles, given that I couldn't do more than ten rows before being forced to downtime. They complained alot, but as I said to them, I can't do magic.
Overall, it's a good method for large areas and/or heavy tiles, and it's really fast when fixing tiles in bulk, but it's still a bad idea to skrimp on materials.
