Discuss tiling on a flat roof? in the British & UK Tiling Forum area at TilersForums.com.
bluesky
hi all ,
just been to price up some more victorian work and one of the floors is going to be on a flat roof which the client has now made into a proper room with glass roof etc so is completely watertight and is a part of the house .need to build the floor up 5-7 mm before tiling .i believe the flat roof is solid 22mm ext ply with the flat roof covering on top .my thoughts are to add 6mm cement boards (or ply)screwed and glued through to the ply which can be tiled on with flex adhesive .any thought /advice - this is not the norm i`m sure !!!
many thanks
mikethetile
is it a built up felt roof
if its felt the felt will slowly compress with the weight, also if its a warm roof construction there could be foam insulation boards between the felt and boarding
its best to have the roof covering off and then treat the floor as you would any other wood floor
its unlikely to be asphalt as that is laid over concrete
Reply to tiling on a flat roof? in the British & UK Tiling Forum area at TilersForums.com
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
I'm about to tile my kitchen with 600mm x 600mm porcelain tiles. I am tiling onto a subfloor...
    Votes: 9 5.5%
    Votes: 15 9.1%
    Votes: 12 7.3%
    Votes: 49 29.7%
    Votes: 20 12.1%
    Votes: 38 23.0%
    Votes: 4 2.4%
    Votes: 21 12.7%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 3 1.8%
    Votes: 5 3.0%
