Jammy
Hi all, this is my first post
I’ve been browsing the forum for advice before I do a tiling job on my ensuite. So far I have purchased a Rubi Star N 60 plus tile cutter and tile drills as recommended by forum members.
OK so the ensuite is upstairs the floor is 18mm thick tongue and groove in good condition – house was built in 1996. I’ll be tiling the floor and walls (porcelain 600 x 300 walls and 400 x 400 floor), and underfloor heating. Room is 3.5m by 2.5m (there are 10 joists in the 3.5m length). I’ve been searching the forums and it seems I need to WBP ply at least 10mm thick on top of the floorboards. If I do this, do I also need the underfloor insulation panels as these are another 10mm. Then adhesive 3mm and tiles 8mm. I don’t really want the floor to be 31mm higher than the adjacent bedroom.
So can I leave out the insulation boards or will this render the underfloor heating too slow to warm-up ?
I’m also in the process of installing a 1400 x 900 JT40 shower tray (in a recess i.e. it has 3 walls) and I’m worried about getting a good seal between the tray and the 3 walls. Can anyone recommend a good quality sealant anti mould flexible etc. I’ve read a thicker sealant bead is better than a thinner one as it has more chance of expanding.
Thanks in advance :8:
