Discuss Tiling on Plywood in the British & UK Tiling Forum area at TilersForums.com.
grumpygrouter
Hi
Just been reading that the americans tend not to use plywood on wooden floors what alternative is their in the UK? They talk about cement backer unit board because of moisture related expansion and contraction issues. Anyone suggest an alternative.
Howard
bear in mind Howard that ply over boarding here is to add strength to the floor because of our construction methods. Maybe the Americans and Aussies have different methods for floor constuction meaning they are solid in the first place, so only use the cement board to give a good surface to tile onto.
Alberta Stone
I have tiled hundreds of jobs onto plywood in Alberta.
Typically the house is made from OSB (3/4 inch T&G) as the primary subfloor, sometimes I see 3/4" plywood, I then put down 3/8" exterior rated sheathing plywood which is glued and screwed to add strength to the floor.
Most tilers here recommend that method.
I don't often use CBU's as they do not offer any structural strength, only a fresh smooth surface.
I use ditra on some occasions as it is a low profile and has nice features.
There is a product from Noble which is an anti-fracture membrane (like kerdi, but better material, chlorinated polyurethane ) that is recommended to be put over plywood to avoid cracking, but I have never seen a floor crack due to the plywood, only if it is a single layer of subfloor or if the tiles were put directly onto dimensional lumber (like 2X10 stairs).
Reply to Tiling on Plywood in the British & UK Tiling Forum area at TilersForums.com
Seems alot of talk that 20kg per mtr2 is the max weight limit for plaster. Few questions 1. its...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Tiling on Plywood
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
