Discuss Tiling on water resistant chipboard in the Australia Tiling Forum area at TilersForums.com.
Hi there
I am new to this and I would just appreciate a little bit of advice. I have searched various forums and cement manufacturing companies who claim that chipboard flooring can be tiled on as long as the floor does not move, there are no gaps and that boards are screwed at 300MM intervals. I have looked at Tilemaster ultimate S2 flexible and it does appear to be for this kind of flooring.
The floor does feel quite solid and on top of the chipboard was 8MM plywood which had a vinyl on top. I had to remove the plywood as floor was too high, or would have been. This was cemented and screwed to the chipboard and was a lot of fun to remove !!!!!
I am in a dilemma as I told customer it could be done, however the thickness of the tiles are 9MM and I don't want to raise the floor any more as there will then be a step up to the bathroom.
My only other possible fix is to remove the 18MM chipboard flooring and replace with 18MM exterior grade plywood which would be quite a bit of work for me.
The floor is in an upstairs bathroom and rests on 400MM joists.
Please any help would be great
Dave
Staff member
Subscribed
389,930
1,000,000
Co.Durham
Tiling direct to a particle board is a BIG no no , no matter what adhesive comps tell you.. Adhesives will stick to it yes , but the integrity and longevity of the installation will be minimal IMHO .
Thanks guys. Oh dear looks like I will be replacing the 18mm chipboard with plywood. At the end of the day I dont want to be going back there !!!! I was just hoping that there would be a slight possibility of not having to do this. If I did put the 9 mm over existing floor and then the 9mm tiles it would be quite a bit higher than carpet outside.
Maybe u should consider a decoupler from Tilemaster or Bal @ > 1mm thick.
Ok thanks, brilliant advise, i really appreciate the help on here. The customer looked annoyed when i told her about the floor and kept asking how much. They are already recycling the radiator and taps that i have removed for cash, and keep saying thry dont want to overspend !!! Sometimes i wonder about folk.
Reply to Tiling on water resistant chipboard in the Australia Tiling Forum area at TilersForums.com
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
Bolton
Business Name
IPR Interiors
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
