alan42
Hi
I have to tile 3 X new build upstair floors each comprising a bathroom (6 sm) and en-suite (3 sm). The existing floor is a product called Weyroc Protect which is 22mm flooring grade chipboard with "resin impregnated Kraft paper on both sides of the board providing double protection and preventing moisture ingress". The boards are screwed directly onto 195mm X 75mm joists and are pretty stable. The rooms will also be laid with loose cable electric undertile heating. The tiles in the bathroom are 66cmX33cm porcelain, and in the ensuite 33cmX33cm ceramic approx 10-12mm thick. Knowing it's recommended not to tile directly on chipboard, I contacted Weyroc for advice, who unsurprisingly extolled the virtues of their product being one of the few that can be tiled directly onto and sent me names of recommended adhesives. The problem is I phoned the adhesive companies who each had doubts about the suitability of their own product in this situation. The adhesives were:
Has anyone experience of tiling over Weyroc Protect. Also what about using latex SLC to cover the UFH and then tiling over using a reasonable flexi adhesive. Would the SLC bond sufficiently to the floor. Last question what is best option to tile onto the dowstairs chipboard without overboarding.
Appreciate any help.
Alan
- Ardex 7001. They thought there would not be sufficient adhesion as the chipboard had some sort of covering, so would not guarantee it would work. Also heard from one of their stockists that this is not the most flexible adhesive.
- Biscem Vitri-Flex. They were worried about insufficient flexibility of the adhesive over the floor made worse by using UFH, so potential for both lateral and vertical movement. Also by using larger tiles in the bathroom there are fewer grout lines to take up any flex.
Alan
