Richard Edwards
Hello Kitl and welcome.
A quick question - is the floor on the ground or 1st / 2nd floor etc and are the joists timber or concrete beams. I assume the UFH is water type. As John has sai we need a bit more info / picture or two to move this forward.
Deflection and movement of the substrate is always a major issue. If this is the case then an Uncoupling membrane on top of any sheet material that you use might be answer.
Please post your additional info and the members on here will help.
