Raj Virky
Hi Tilers, About to tackle the biggest job left, the kitchen tiling with 60 x 30 porc. with electric ufh/insulation boards and with flexible addy. However there is a wooden patio frame in the way which i'm going to cut into for the right depth(flush with insulation board, any lower would be even harder.) So a small part of the tile would end up on top of the frame. Pic. below. A few ideas are:
1. Use a decoupling membrane, but for such a small area?
2. Its such a small area forget about it or
3. Tile up to the frame and cut a smaller tile here (7cm x 30/60) and Silicon every grout joint around them.
Tiles are RAK polished black. with none/negligible bowing, did see another batch that was out 1mm both sides though. Thanks for reading.
