Discuss Tiling onto a polystyrene bath panel!? in the UK Tiling Forum area at TilersForums.com.
Onlinetiler
My client has a V&B bath (plastic) which doesn't have legs, it just sits into what is effectively a polystyrene box. The polystyrene panels are approx 50mm thick, and needless to say there's a fair amount of flex in the long side panel.
I thought it may have been some kind of packaging but have looked thru the V&B instructions and sure enough they recommend tiling straight onto the polystyrene.
I've never come across one of these before and wondered whether anyone else had experience here. Any thoughts on products, techniques etc would be gratefully appreciated.
Colour Republic
I know you can tile directly onto some of the polystyrene building block systems (but always thought that seemed a bit stupid as coming to remove them would destroy the wall!) So can't see why you couldn't tile on to this stuff if it's the same grade poly as that. But in all honesty if there is flex in it, doesn't sound that great to me! is there any room to dot and dab plasterboard to it? or is there just enough room to tile?
Reply to Tiling onto a polystyrene bath panel!? in the UK Tiling Forum area at TilersForums.com
Hi there, long time lurker, first time poster. I’ve recently moved in to a new build property...
Trying to Get bathroom re tiled, had conflicting advice from a few tilers, I’m a total novice...
6K
Hello all I need a recommendation for a bath panel sized tile backer board. Only slight...
5K
Perry
Hi all, I've put water underfloor heating down in our bathroom using "ProWarm Warm panel" which...
5K
J Sid
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
