Discuss Tiling onto brick in the British & UK Tiling Forum area at TilersForums.com.
F
Fekin
Going by Bal's product sheets for Whitestar it does say...
Suitable for use in dry and wet duty locations including heavy duty commercial applications such as communal showers and commercial kitchens. Ideal for use on a variety of backgrounds including cement:sand rendering, plaster, plasterboard, paint, sheets and boards, tilebacker panels and existing ceramic tiles.
...so paint is listed, even though most do recommend removing as much paint as possible before tiling.
Personally I would rough up the paint with a wire brush as much as possible first, then use an acrylic primer as it dries tacky giving extra sticking power then something along the lines of Bal's Whitestar adhesive.
calculator
The bond strenght of any paint may well be the weakest link. Epoxy paint on floors and gloss paint on walls are usually strong enough but emulsion paint must be removed mechanically, (no chemicals). Try putting a strip of gaffer tape on the wall leave for 5 mins and then slowly peel off if the paint comes away you will have to remove as much as you can and then score with wire brush, hope this helps
CLAYS TILES
I'm glad you brought this up as next week i've got a job on in a toilet, 7x3 ft, just the WC in there but the walls have backing paper on thats been painted over a number of years i've been told!
i told them to remove it if possible but if they can't / don't wot would be the best solution?
would i score it or something else??
thankyou for any help you can give:(
Reply to Tiling onto brick in the British & UK Tiling Forum area at TilersForums.com
Hi all I've got a newbie question here! I've got a kitchen splashback coming up soon with...
Hi. I hope its ok to ask a question on here. I am changing my shower surround. The tiles in my...
Tiling onto brick
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
