Discuss Tiling Onto Decoupling Mat in the British & UK Tiling Forum area at TilersForums.com.
F
foxman
Hi worked up in Aberdeen last year on a 1200 square meter granite floor job, because the sreed had'nt gone off and the water moisture content in the screed was to high, to lay tiles we had to use a decoupling mat. This was a plastic mat that you laid down onto the screed then tiled in the normal way, the mat was actually a floating membrane. I think it was called Watec. Has anyone else used this system before and what did you think. Cheers Mick
MJT
I've used this type of decoupling membrane before it's called, Watec 2e matting used it on a floor which had two substrates wood & concrete.
It's differant than ditra matting , you dont stick it down you just lay it down and tape the joints.
Also used it on bitumen substrate to. Never tiled a floating floor in my life always walked away from them.
Well thats what I thought but using Watec 2e matting is a floating floor.
Reply to Tiling Onto Decoupling Mat in the British & UK Tiling Forum area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
I've just had the whole ground floor of a house we are working on levelled with a pump in liquid...
Bishbbashbosh
hats67 - Yesterday at 11:48 PM Add bookmark #1 Hello guys. I came upon and registered with...
Hello guys. I came upon and registered with this forum while doing some research on decoupling...
5K
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
