Discuss Tiling onto dot & dabbed walls in the British & UK Tiling Forum area at TilersForums.com.
geoffr
I've just dot and dabbed some plasterboard on a 2m squared wall and need to know if I have to fix it to the wall with any other fittings before I start tiling. I'm using 25mm x 33.5mm tiles (6mm thick) with a mosaic border.
Also, I've been told by my brother in law to use floor adhesive on the walls especially around the shower area as this will be more waterproof. Is this ok to do?
Geoff
F
Fekin
As penno said, don't bother with flooring adhesive, use something along the lines of Bal Whitestar as it gives good grip and excellent water protection.
Tanking "in my opinion" isn't needed for domestic showers areas as long as you do a good grouting job, and use a good microban Silicon and grout.
penno
Yeah agree Fekin wouldn't bother with tanking myself mate but an option if you want that added extra protection.
And BTW geoffr tanking is basically a system you can buy from any good tile retailer that is applied to the walls to make the area waterproof. (if you didnt know)
GazTech
Geoff
This will be perfect for you.......Gaz
BAL Prime APD
A modified acrylic polymer dispersion for use as a primer for a variety of backgrounds/bases prior to fixing ceramic tiles, mosaics and natural stone and prior to the application of levelling compound and the BAL WP1 TANKING SYSTEM. BAL PRIME APD isolates products containing calcium sulphate such as gypsum plaster and anhydrite screeds from cement-based adhesives, thus minimising the risk of reaction between the two materials.
BAL White Star
White, highly flexible, non-slip, highly water-resistant ready-mixed organic dispersion ceramic wall tile adhesive utilising the latest raw material technology and employing the highest quality acrylic resins. Conforms to BS EN 12004 for a D2TE Adhesive.
Suitable for use in dry and wet duty locations including heavy duty commercial applications such as communal showers and commercial kitchens. Ideal for use on a variety of backgrounds including cement:sand rendering, plaster, plasterboard, paint, sheets and boards, tilebacker panels and existing ceramic tiles. Suitable for use on worktops.
BAL Microflex Wall Grout
A White cementitious tile grout especially formulated with built-in Microban® antibacterial protection to inhibit the growth of bacteria, such as Listeria, Salmonella, E-coli and black mould. It provides an added level of hygiene protection in bathrooms, showers and food consumption areas. The grout also has built-in admixture to provide flexibility and to enhance the bond to the edges of tiles and mosaics. Conforms to BS EN 13888, Type C, Class G2.
in that order....Gaz
Reply to Tiling onto dot & dabbed walls in the British & UK Tiling Forum area at TilersForums.com
We had a wet room fitted by a large company. We have issues with a few large steps where the...
Hi all, I am in the middle of renovating my bathroom. First of its kind for me! The walls were...
5K
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
