Discuss tiling onto painted surfaces in the British & UK Tiling Forum area at TilersForums.com.
mikethetile
when you use tape make sure its not the easypeel masking tape as that will not pull the paint off
its a bad idea anyway even if the paint doesnt peel, paint shouldnt really be tiled over, its not just an issue of the paints adherance to the wall, its also the lack of suction in the paint surface can cause poor adhesion to the painted surface
theres no need to strip the paint, score it through so the adhesive is sucking into the substrate rather than not sucking into the paint
L
loaderman
I always start with the ducktape test. If paint comes off with it then its all got to come off.
I use one of those really sharp 4 in wall scrapers. Normally does the job fairly quickly. Sometimes I also use a hot air gun to soften the paint a bit to help it along before scraping.
Rapid set adhesive also helps reduce the risk of the addy bringing off the paint.:thumbsup:
Reply to tiling onto painted surfaces in the British & UK Tiling Forum area at TilersForums.com
Hi, can anyone advise me on how to prep a painted brick or block wall for tiling? Do I just wash...
    • Friendly
Hi there, We have red quarry tiles in our indoor entrance hall and my wife would like to paint...
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
