Discuss Tiling onto plaster on terricotta brick wall in the UK Tiling Forum area at TilersForums.com.
Robb o
Are you talking about Porotherm or sometimes called 'spanish block'?
If you are I would say that these walls are installed on a 1 mm bed of mortar along the horizontal perp and they lock together,with no mortar between the vertical perp.
You are right they are not the strongest and I have seen alot of movement if they are only a single block width.
Has insulation (celotex) been fixed to the wall before plasterboard? as this will also make a difference on your tile weight.
Reply to Tiling onto plaster on terricotta brick wall in the UK Tiling Forum area at TilersForums.com
Seems alot of talk that 20kg per mtr2 is the max weight limit for plaster. Few questions 1. its...
Hi all, hoping for some advice. We purchased some splitface slate tiles from tilegiant and had...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
