Discuss Tiling Onto Ply Wood in the Australia Tiling Forum area at TilersForums.com.
J Sid
Scott1989
I've taken your advice and covered it with hardi backer board, the trouble I have now is with the tiles. They are small brick tiles. And using a 6mm trowel the adhesive doesn't seem to be getting enough on the backs of the tiles. The outer edge is getting caught by the adhesive but the middle isn't. Should I use a 10mm trowel or dot and dab the tiles on the wall
Bill
Have the tiles got concave back? .... I did some brick tiles last year that were like this. Only option is to back fill the tiles. If you use a bigger notched trowel the adhesive will start to come through the joints and that will leave you with more cleaning to do and may take you longer.
Reply to Tiling Onto Ply Wood in the Australia Tiling Forum area at TilersForums.com
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
I'm about to tile my kitchen with 600mm x 600mm porcelain tiles. I am tiling onto a subfloor...
Hi am re tiling kitchen and want some ideas as to what’s best to repair the walls after Remiving...
Some helpful advice/opinion would be appreciated... Existing tiles on walls, some of the walls...
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
