Tiling onto 'solid' lathe & plaster wall
Sure i responded to this in another thread, must not of done it right, blinking iphones.
Same as everyone above, never seen a solid one.
For what it would cost, no more than a day with gear you may as well knock off and re board
Ok thanks all, time to bite the bullet then I guess. I did try and add a photo but it wouldnt let me?
The other wall of the shower is an external wall with the plaster applied to. Will this also need pulling down and boarding?
i57.photobucket.com/albums/g233/sigurney/2D91A00A-AE8C-45AE-9095-38018DEF9CE8-772-00000077B7E28D45_zps3cb3e97d.jpg
Is it lime mortar or a modern gypsum basecoat.....
I tiled a bathroom this week infact where the customer didnt tell me they had lath and plaster walls ,they were concealed behind dot and dabbed plasterboard I only found out when i chopped back some making good he had done with my plasterers hammer to find out they were lath and plaster , The bathroom was 90% complete too , I finished the job and was paid but I did tell them that if I had of known I would not have tiled it
First time I've ever heard of that, unbelievable.
Old thread but forgot I posted here. I ended up taking it all down and fitting 20mm marmox.
Stud walls I levelled the studs and added for where fittings like shower frame went. Also filled it with rockwool. The brick walls were external and dot and dabbed with the marmox spankers.
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
