Discuss Tiling Onto Uneven Concrete/bitumen Floor in the Australia Tiling Forum area at TilersForums.com.
Markhi43
Problem:
  • Tiling a kitchen floor.
  • Half is covered in bitumen (from parquet floor). Half is a new concrete slab.
  • There is a 35mm level difference across the floor and is fairly lumpy.
Possible solution No.1?:
  • Use latex self-levelling compound such as arditex na.
  • BUT: I am slightly worried the new slab may move and crack along the joint. Which will crack the slc and the tiles.
  • BUT: This solution will offer no insulation and due to the level difference will cost an arm and a leg!
Possible solution No.2?:
  • Lay chipboard tounge and groove flooring. Using an adhesive to take make it level (in a similar fashion to dot and dabbing) then tiling onto that. Maybe screwing it to floor as well
  • BUT: will this stand the test of time?
  • BUT: is there an adhesive available to do this?
Please, please help. Gone round and round in circles with this one. Thank you in advance
Hi and welcome to the forum Mark!
Yep problems.
Firstly I spose, who are u to this job?
You're own home?
Are u a tiler?
Builder?
Diyer?
Oh option two! Nah! Haha
This is why we ask new members to post here first, to tell us a bit about yourself so that we can help u best way we can. :)
Welcome Forum | New Members Say Hi Here
It's difficult to assertain what level of advice to give otherwise.
I
Ian
Alright. Thank you for your advice. I'll talk it through with the other half . Her folks are insistent on the chipboard sub-floor.
Do not turn a concrete substrate into a wooden one, that is not a good piece of advice. Clean the bitumen up and level the floor. Even if you were to put chipboard down (which you shouldn't even consider), you'd still need to put a backer board over it to make it tileable, all those layers would leave you with a 40mm step into the room.
Reply to Tiling Onto Uneven Concrete/bitumen Floor in the Australia Tiling Forum area at TilersForums.com
So I may have done an oopsie. We are putting self-levelling compound down over floor where I...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Will this work? (top to bottom) tiling (one room), 12mm laminate (other room) 19mm T&G chipboard...
    Votes: 5 4.1%
    Votes: 11 9.1%
    Votes: 7 5.8%
    Votes: 33 27.3%
    Votes: 16 13.2%
    Votes: 31 25.6%
    Votes: 3 2.5%
    Votes: 2 1.7%
    Votes: 19 15.7%
    Votes: 18 14.9%
    Votes: 13 10.7%
    Votes: 6 5.0%
    Votes: 3 2.5%
    Votes: 2 1.7%
