miksto
I've used some latex self-levelling compound to even out a concrete floor prior to tiling. Unfortunately the surface hasn't ended up as flat as I was hoping, with ridges left in some places where the flow ended. I had to pour the self-levelling compound from two different corners of the room (because of a slight hump in the middle of the room plus a rise in the third corner) and was unable to get things to marry up cleanly in the middle. The result is somewhat disappointing, I have to say.
I've laid some tiles out without adhesive just to see how flush they fit to floor. Alas, in many cases there is a bit of wobble present rather than even contact across the whole surface area of the tile. Can I deal with this by varying the thickness of the tile adhesive or do I need to get the floor 100% flat before tiling, perhaps by pouring another coat of SLC?
I'm reluctant to do the latter, in case I end up with same problem as before and because the stuff is expensive. I’m tempted to see what I can do with the tile adhesive - if the worst comes to the worst and I end up with one or two cracked tiles I can always replace them - they're only cheap ones and I have quite a few spares, and it's my own property and I'm not moving out in a hurry. How quickly would a failure in a particular part of the tiling become evident and how easy is to replace a cracked tile should this happen?
Any suggestions would be much appreciated.
Thanks,
Mike
Thanks,
Mike
