Discuss Tiling outdoors advice in the Canada Tile Advice area at TilersForums.com.
That’s correct, there’s no need to water proof a concrete patio. The whole concern is avoiding water pooling or gathering in a volume that when it freezes starts the process of expanding and forcing the tiles to break from the adhesive. The first ‘gap’ created gets bigger and when the second freeze occurs this problem gets bigger and so on and so on until there is a failure, so the emphasis is on draining the water away so as to prevent this in the first place.So basically theres no need to waterproof the concrete substrate? Is this correct
Not to state the obvious but do make sure that the concrete is prepared correctly for tilingThanks
The only thing is if schluter are that confident why do they make drain 8Guys after extensive research ive found out maybe I dont need ditra drain .
Check out this video
They actually do showThey didn't show the cold freezing the trapped water after the rain.
@Schlüter-Systems Ltd are forum sponsors so I'm sure if you call them they'll give you the correct information.
Reply to Tiling outdoors advice in the Canada Tile Advice area at TilersForums.com
