Discuss Tiling over 22mm T&G chipboard in the Canada Tile Advice area at TilersForums.com.
MarshallTile
Hi contact Nicobond technical and they will talk you through it. Found it hard to believe myself but it works even on floor boards provided the floor has not too much deflection and you use a quality flex adhesive.
PM me for the Yorkshire rep's telephone number
***edited by admin - sorry phone numbers not allowed in the open forums ***
Dumbo
I’ts not a product I use personally but I’d suspect the mesh adds lateral strength to the build up and creates an almost independent slab so to speak. I’d prefer to go with Ditra as the tried and tested and easiest option.
Maybe it should be called plastic chicken wire rather than plastic ply .
Mark1979
You should not use an s2 with ditra
Thanks - I can see the dural will work with S2. Given the suggestion above about using both hardi board and a decoupling membrane is there any benefit in me putting dural on over the hardi as it'd only cost a few hundred at this stage or is it overkill / no benefit?
Hi, I've just googled it and am no expert so please ignore my ignorance, but I'm struggling to understand how this works if everything I've been told about Ditra/Hardie method is correct. How is it better then just tiling on chipboard as surely the plastic mesh just transfers any movement from the wood to the tile?
N&C Plastic Ply is an anti-fracture mesh that is 2mm thick. To be laid on timber floor and it counter acts deflective forces caused by the natural movement in timber floors
Watch the video Easy to cut, lay and it does work (It is NHBC Approved)
Reply to Tiling over 22mm T&G chipboard in the Canada Tile Advice area at TilersForums.com
Hi - I'm laying hardiebacker on top of green chipboard. I have a load of Mapei Primer G left...
Seems alot of talk that 20kg per mtr2 is the max weight limit for plaster. Few questions 1. its...
Hi all, I want to tile over a completely new floor. New floor joists have been installed with...
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
