Discuss Tiling over a tongue and groove wooden floor boards laid on concrete in the British & UK Tiling Forum area at TilersForums.com.
F
figgy2000
Hi,
This is my first post so Hi to everybody!
My question being I want to tile using Travertine tiles on to 20mm thick tongue and groove floorboards which are glued using a bitumen type substance and also nailed at intervals directly into a concrete floor - do I need to use a tile backer board 6mm or 12mm or can I lay the tiles directly onto the tongue and groove using a suitable flexible adhesive??
I can feel no deflection/movement whislt walking on the floor as I can when walking on a wooden floor fixed to floor joists it feels extremely solid
Ajax123
1,213
Lincolnshire
Ive seen bitumen used to stick bords as well but not nails. Perhaps it was nailed to try and stop it curling cos the concrete was wet. The nails will probably prove tough to get out as they will haverusted into the concrete. I agree though that hey should be removed and tiles directly to concrete
Staines
Can I ask whether you removed the bitumen strips before laying the marmot. I am about to be faced with the same challenge and wanted to know how you got on. I am about to lay marmot onto a floor which had parquet flooring. There is currently remains of bitumen. What adhesive did you use? Did you also screw the marmot?
Reply to Tiling over a tongue and groove wooden floor boards laid on concrete in the British & UK Tiling Forum area at TilersForums.com
Good afternoon, Does anyone have experience of using grooved dry screed boards? (Bonus points...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
