Discuss Tiling over existing tiles in the British & UK Tiling Forum area at TilersForums.com.
mwss77
Hi all
Need a bit of advice on this one please, Start a job on Monday that requires me to tile over the existing tiles in a bathroom.
Never had to do this before, the tiles already up are fixed on solid, so what is the best way to prep them before applying new tiles over the top.
I hav heard you can mix pva and sand and paint this over the tiles
Help please.....:thumbsup:
Mark
GazTech
Don't use PVA, just wash the tiles down with sugar soap, this removes grease etc from the surface. Then being a bathroom, a good D2 type adhesive is recommended.....Gaz
BAL White Star
White, highly flexible, non-slip, highly water-resistant ready-mixed organic dispersion ceramic wall tile adhesive utilising the latest raw material technology and employing the highest quality acrylic resins. Conforms to BS EN 12004 for a D2TE Adhesive.
Suitable for use in dry and wet duty locations including heavy duty commercial applications such as communal showers and commercial kitchens. Ideal for use on a variety of backgrounds including cement:sand rendering, plaster, plasterboard, paint, sheets and boards, tilebacker panels and existing ceramic tiles. Suitable for use on worktops.
sWe
Personally i would always try to get the customer to have the old tiles removed as your never 100% sure how well the old tiles are fixed also with two sets of tiles on the wall it will be double the weight.....
I agree completely.
I'd use epoxy primer when tiling on old tiles btw. I'd clean the surfaces using sugar soap and a polishing machine with a rough scotch brite pad first though.
robbo
If your going to use a good strong adhesive Like Bal white star as Gaz suggested you might not need to use a battern, all depending on size and weight of tile really, just keep checking with sprit level.
Very handy for supporting battens or straight edges used at the bottom of wall tiling.
Normally nails would be used to secure the batten to the wall. Quite often you will be unable to find any thing solid to nail to. sometimes the opposite, you find the wall too hard
Use these stands to get the batten supported at just the perfect height in seconds
sold in pairs
weight 1.7 Kg per pair
Price: £10.50 £12.34 Including VAT
You could try these, but i've never used them and don't really know how good they are?
Reply to Tiling over existing tiles in the British & UK Tiling Forum area at TilersForums.com
Some helpful advice/opinion would be appreciated... Existing tiles on walls, some of the walls...
    Votes: 9 5.3%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.7%
    Votes: 21 12.3%
    Votes: 40 23.4%
    Votes: 4 2.3%
    Votes: 4 2.3%
    Votes: 24 14.0%
    Votes: 19 11.1%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
