Discuss Tiling over floorboads in a bathroom in the Bathroom Tiling Advice area at TilersForums.com.
aled
Hi,
I am renovating my property and the bathroom needs a complete overhal. At the moment the bathroom has floorboards. I am not happy to simply tile onto the floorboards as there could be some movement with them. So, with this in mind i need to make the floor more rigid before tiling. Should I: -
  1. Fix plywood on top of the floorboards. I have read that to do this i need to use 12mm WBP plywood screwed every 150mm. The only issue with this is that it could cause a step from the landing into the bathroom. Something I would like to avoid if at all possible.
  2. Remove the existing floorboards and fix plywood directly onto the joists with 25mm WBP plywood fixing noggins where boards join across joists.
I am not in the trade and I have no idea what I exactly need to use in order to make the floor ready for tiling. I would be grateful for your help and advice.
Thanks in advance
Perfect Tiling
I normally leave a 2-3mm gap which is then mesh taped over, filled with adhesive and levelled off...just like plasterboard. Also best to stagger your boards and put them down in the opposite way to which the floor boards or chipboard go. Not always possible and if its only a small room then not always necessary.
Reply to Tiling over floorboads in a bathroom in the Bathroom Tiling Advice area at TilersForums.com
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
Unsolved
    Votes: 9 5.5%
    Votes: 17 10.3%
    Votes: 12 7.3%
    Votes: 46 27.9%
    Votes: 21 12.7%
    Votes: 39 23.6%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 5 3.0%
