Discuss tiling over old floor boards ? in the British & UK Tiling Forum area at TilersForums.com.
groucho
Tiling bathroom floor in old cottage. was going to use dittramatt as its tens times easier to lay than ply etc. But boards a bit uneven here and there. Couple loose. Is this the best option? boards very dirty sugar soap? if laying dittra , to help leveling out for matt can you just splogde a bit of flexy down ? thanks
DHTiling
ho groucho mate...
Some peeps think you can use ditra to replace ply or cement boards for strengthening floors but is not so....
You have to make sure a floor is solid before using it...Ditra main purpose is a crack isolator and anti fracture membrane...like old concrete floors and solid wood floors with lots of joints etc etc....it is also a vapour release mat, so is ideal for tiling onto green screeds etc....
here is a link to schluters ditra page... http://www.schluter.co.uk/produkt.aspx?doc=6-1-ditra.xml&pg=funktion
Ditra is good also if you are u sing travertine on timber floors after being strengthened the ditra will take some of the stress off the travertine preventing it from cracking as it sometimes can on timber substrates...
So my advice would be to strengthen the boards and over-ply first..and use ditra if you think it needs it......good luck....:thumbsup:
DHTiling
Some formats of travertine are quiet large..they are honed and filled most of the time and its at these points that they can crack...Ditra will help with this type of stone to relieve some of the stress from the timber expanding etc etc....but as with all tiling to timber floors the substrate needs to be firm first and formost..
hope this helps...
Reply to tiling over old floor boards ? in the British & UK Tiling Forum area at TilersForums.com
Hi, Soon to lay 500mm sq tiles onto screeded hall/kitchen floor 25m2. Hall floor has vinyl...
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
    Votes: 9 5.3%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 48 28.4%
    Votes: 21 12.4%
    Votes: 40 23.7%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.6%
    Votes: 19 11.2%
    Votes: 17 10.1%
    Votes: 8 4.7%
    Votes: 5 3.0%
