meh just wish it wasnt so hard to get someone decent out... I dont mind paying if I know it is going to be a good job but like i said round where I live there are a lot of people who cut corners 🙁
like i said the brickwork is dry... the plasterboard had seemed to have gotten wet from the surface of the plaster... gona carry on chipping away at the plaster tomorrow... might just get some brick acid and clean up the bricks and leave it at that 😛
yes as the dude said he could level the walls using this cement mix and then I could tile onto it but as he said that I should 'PVA' the wall before tiling i thought id check on here as im pretty sure pva if it got wet wouldnt be the best thing to prime a wall with
the cement will draw too much moisture out of the tiling mix so i want to know what to use as primer (if even needed) and if not then what sort of adhesive should i used for the tiles
