Discuss Tiling over tiles primer in the Canada Tile Advice area at TilersForums.com.
Hi and welcome to the forum Rob.
I wouldn't 'recommend' tiling on to tiles usually, do you have a few more details?
Existing tiles?
Wall or floor?
Original substrate?
New tiles?
Thanks!If it's floor and they are not hollow why not?
Primer - mapei eco grip prim. Make sure you stir it before applying. The sand sits at the bottom of the container. ..
Thanks. I think I'll scuff them up as you suggest and then prime.Only a small area then.
I'd try orbital sander or grinder with sanding pad/disc to take off shine and then use a prime and grip primer as described above.
Mapei, Isomat and tilemaster all do one.
You'd like to play with gws7 115e-Only a small area then.
tell the truth
same sameYou have found my secret passion Antonio!
Reply to Tiling over tiles primer in the Canada Tile Advice area at TilersForums.com
