Discuss Tiling path and step in the Canada Tile Advice area at TilersForums.com.
Bob2
Hi all.
I have a job that I'm unsure of how to approach, and I have 2 queries.
I need to lay 10mm porcelain tiles onto a newly poured concrete path. Path has been down for approximately 8 weeks. I am going to use Keraflex S1 Maxi as the adhesive.
1. Can I fix the tiles directly to the path or do I need to use an uncoupling membrane first? If so..which is the best membrane to use outside?
Also, the poured concrete path runs continuously into the house and forms a new step. I will be laying 20mm porcelain slab as the doorstep and a new composite door will sit on top of this. I am then tiling the indoor part of the path/step again in 10mm porcelain tiles.
2. Can I use a floor insulation board such as prowarm on the inside to raise the level to the door and also provide a minimal level of insulation? And would I again need to use an uncoupling membrane under the board?
I have attached photos of the path to be tiled. Where the door sits now is where the new door will also sit on the edge of the 20mm slab.
I would appreciate your advice as am unsure of the best approach.
Cheers, Richie
Bond
528
Highland
Given the size of the areas to be tiled , you could tile direct to the concrete slab with flexible adhesive , although belt and braces approach would be to use an uncoupling mat such as Ditra 25, or Dural Cl++. Good shout with the insulated tile backer board internally as you have a potential cold bridge situation at the threshold, flexi addy again direct to board will suffice.
Bob2
Thanks Bond. The path outside measures 2.8m x 0.9m wide...do you think this would be fine without the matting then? I have put mesh and fibres in the concrete to help prevent cracking. Was hoping to just prime the concrete with Mapei Primer G then tile onto that?
Reply to Tiling path and step in the Canada Tile Advice area at TilersForums.com
Hey guys, I'm going to tile the patio and need my new porcelain tiles (10mm) to meet up with...
Hi guys, had some great advice here before so thought I would ask here for advice again...
Help! New DIYer here - I’m preparing my bathroom floor to lay ceramic tile. Removed the vinyl...
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
    Votes: 5 4.1%
    Votes: 11 8.9%
    Votes: 7 5.7%
    Votes: 34 27.6%
    Votes: 16 13.0%
    Votes: 31 25.2%
    Votes: 3 2.4%
    Votes: 2 1.6%
    Votes: 19 15.4%
    Votes: 18 14.6%
    Votes: 14 11.4%
    Votes: 6 4.9%
    Votes: 3 2.4%
    Votes: 2 1.6%
