Discuss Tiling patio? in the UK Tiling Forum area at TilersForums.com.
rh.321
Hi all.
This is my first post. I'll try and keep it short.
I'm tiling my patio (60m) with Porcelain tiles and could do with some advise.
The patio construction is as below. I'm up to concrete stage.
  • 150mm hardcore
  • 150mm concrete (reinforced)
  • Liquid DPM
  • 65mm cement screed
  • Bal primer
  • Ditra mat
  • Tile (Porcelain retified)
  • Bal floor Epoxy
The question is.
  1. What adhesive should i use to stick the Ditra and tile down with. I've was going to use Bal Goldstar but after taking to Bal technical they recommended i use Rapidset Flexible. Thats ok but the price is a lot higher than Gold star.
  2. As the screed is green, should i use Bal Green Screed to stick the Ditra mat? One of the advantages of using the Ditra was not having to wait 30 days for the screed to fully dry out. (not easy to keep the screed dry in the garden)
Thanks for any advise you can give. I've done quite a lot of tiling including my kitchen floor thats was 45 square metres but i'm no expert.
Any recommendations would be appreciated.
Rob:8:
True Tiling
Hi rh, I am a tiler with over 7 years experience, and I have an almost exactly the same project as yourself, which I am undertaking on Monday. I have opted to self-level the 50sqm+ patio area with 20 (25Kg) bags of Ardex K301 exterior levelling compound and trowel it out/spike roller to take out the </=6mm differences in height. I found that this is a more cost-effective way (still£ 800 in materials), but requires skills...
Reply to Tiling patio? in the UK Tiling Forum area at TilersForums.com
Tilers Forums on FB
